my lca re-locating brackets have a top and bottom hole.which do i use for dragracing?
I've got UMI re loc brackets and use the bottom hole, zero wheel hop. I did however read somewhere that for some reason you were better off using the middle hole if you had no wheel hop, don't know why though.
Do you guys have to use any washers or spacers to get your LCA's to fit into the bracket's right. Because i have about a 1/8th in. gap between the braket and my LCA's. Just wondering what i can do. I have washers in there right now but that just doesn't seem right. Any suggestions
Perhaps I don't under stand your question, however washers at the LCA/ Reloc Bra interface will only shift the axle to the left or right side of the car. An adjustable panhard rod will do the same thing. After market LCA's may have to be shimmed.
