were can i get a nice turbo cam for me
Old 06-17-2006, 05:06 PM
MiaSSmaro98's Avatar
Default were can i get a nice turbo cam for me
well my setup will stock block,stock internals,patriot lq9 heads,edelbrock victor jr,custom elbow,stock ported t-body,t70 turbo,6.0 truck ex mani on drive side and 01 ls1 camaro ex mani on pass side match flow to the truck mani.ohh and it will most likely be a speed destiny tune and it will be a daily driver.
Old 06-17-2006, 05:11 PM
cws T/A's Avatar
lingenfelter
Old 06-17-2006, 05:42 PM
Senior Member
Country Boy's Avatar
The LS6 cams has done wonders and Im going to be running the LPE GT2-3
Old 06-17-2006, 06:43 PM
mdhmi's Avatar
Both the LS6 and LPE GT2-3 cams are perfectly fine, however if you're going to the trouble of doing a cam swap I'd have a custom reverse split cam ground. CamMotion or Comp can grind whatever cam you like.
Old 06-17-2006, 06:52 PM
Senior Member
You can pick up a used LS6 cam very cheap as I did with my LPE cam
Old 06-17-2006, 06:55 PM
joffa's Avatar
what cam would give best results in a 402ci turbo motor? does single or twin turbo make a difference?
Old 06-17-2006, 07:00 PM
Bryan @ Speed Inc.'s Avatar
that depends on your set-up and purpose of the motor.
cars that see a lot of street miles or even daily driven, i would say stay with a smaller cam. you don't need huge cams to make great power with forced induction.
single and twins, there is a big difference, but that's a whole 'nother can of worms. don't hijack the guy's thread.
Old 06-17-2006, 07:02 PM
speed inc's 225/225 113lsa "boost cam" ... that cam powers a few 800+ rwhp 6spd cars.
Old 06-17-2006, 10:09 PM
ou812/z28's Avatar
call futral motorsports...allen has had some big #;s with his cams. 877-784-3278.....
Old 06-17-2006, 10:30 PM
Senior Member
careful with the cam maotion cams. There have been a lot of people wiping lobes on them..
Old 06-17-2006, 10:37 PM
ou812/z28's Avatar
i have ran a cam motion cam in my lt-1 for 4 years and have had no problem.....i got my turbo cam about 6 month ago from him to go in my ls-1 so hope not to have any problem....
Old 06-17-2006, 10:43 PM
wats the reverse split cam?and i read that u have to match ur cam to ur mods?so if i have good intake flow and mild exhaust i need the intake duration larger then the ex. duration is this correct?and nore the ls6 or lpe's follow this method
Old 06-17-2006, 11:00 PM
cws T/A's Avatar
other way around for a fi engine the air will be pressurized at the intake valve going in turbocam helps get the flow out on time reverse split looks like this int/exh 224/ 220 @.050 .585'' .560'' 113-115ls
Old 06-17-2006, 11:05 PM
cws T/A's Avatar
this would work great , call around and get some opinions
Old 06-17-2006, 11:32 PM
so a split cam is just a cam with a higher intake duration then the ex duration?
Old 06-17-2006, 11:49 PM
cws T/A's Avatar
reverse split is higher int than exh duration and lift 224/220 580'' 560''
normal 220/220 580'' 580''
split duration 220/224 560'' 580''
Old 06-17-2006, 11:51 PM
mdhmi's Avatar
I know tons of people with CamMotion turbo cams. If any of them had issues I wouldn't have recently ordered one. Sure the failure you're thinking of wasn't installer related?
Old 06-18-2006, 01:06 AM
red90cobra's Avatar
think it was futal had a bad batch from them. at the beginning of the year i think.
Old 06-18-2006, 08:05 AM
Senior Member
Theres been a rash of them lately in IE section.
Old 06-18-2006, 08:44 AM
so for my setup which one will be better?reverse split?split?or normal?
Quick Reply: were can i get a nice turbo cam for me
