Valve Springs for 660 lift Hydrolic Cam?
Old 06-17-2006, 06:59 PM
Nine Finger 02 Z28's Avatar
Question Valve Springs for 660 lift Hydrolic Cam?
Anyone have any sugestions?Thanks
Old 06-17-2006, 09:25 PM
Beast96Z's Avatar
I'm using PSI 1225's good for .700". These are for .100" longer valves though. 1.950" install height I believe. I'm also using delwest "super light" titanium retainers. It's high dollar stuff, but should keep the bigger valves under control.
Old 06-17-2006, 10:41 PM
DavidNJ's Avatar
Will his head fit that spring? CV also has a PSI LS 1512 that is rated for .65 but looks like it can be stretched to .67. 1.27 diameter and special surface finish. However, I wouldn't be surprised if they are $500-600/set.
Old 06-17-2006, 11:03 PM
Randy WS6's Avatar
PRC duel springs are good for .660 lift , im useing them with my Crane .650 lift
Old 06-17-2006, 11:12 PM
These ?
Patriot Valve Springs
Part #
Description
MSRP
8401
Partiot "Gold" .650" Lift Dual Spring Kit
Includes: Patriot "Gold" Springs, Titanium Retainers, Machined bases, Super 7 Locks, & Viton Rubber Seals
$255.50
Old 06-17-2006, 11:19 PM
Randy WS6's Avatar
Texas Speed Inc.
http://www.texas-speed.com/shop/item...d=173&catid=48
Old 06-17-2006, 11:21 PM
Thanks.
Old 06-18-2006, 11:51 AM
GuitsBoy's Avatar
Yeah, the PRCs are rated for .660 however im not entirely comfortable using them maxxed out. But your only option may be milling out the valve spring seats for larger diameter springs...
Old 06-18-2006, 12:21 PM
DuronClocker's Avatar
I'm using the Patriots with my .641/.646" cam and I haven't had a problem. I obviously don't have them shimmed at all.
The PRCs are rated .660 instead of .650 because I believe their retainers are a bit different and locate the spring slightly higher.
Old 06-18-2006, 12:51 PM
fast98's Avatar
i have the same cam but the prc springs and i shimmed them .015 i could have shimmed more........
Old 06-18-2006, 01:03 PM
ninobrn99's Avatar
what exactly are you all using for shimms and where are you getting them?
Old 06-18-2006, 01:13 PM
fast98's Avatar
i got mine from thunder racing, i think the kit is made by lunati specifically for ls1's it comes with 16 of each .015" and .030"
