Suspension & Brakes - Cutting 1/2 Coil on SLP Eibach Springs = What?
Billiumss
06-18-2006, 06:19 AM
Last spring (2005), TrackBird and Pimpmaro came over to help me install my SLP Eibach lowering springs.
It's been over a year now since I got them installed. The rear settled down about 1 - 1 1/8 inches (Perfect) and the front only settled down about 5/8 of an inch from stock height.
Kevin (Trackbird) said that I could cut a half coil off my front springs. Would that give me another 1/4-1/2 drop? Do you cut the top or bottom of the coil?
I like the way it drives and feels so I don't want to get other springs, just want to "fix" the front SLP springs.
Caswell
06-18-2006, 03:12 PM
2/3 of a coil was an additional 1/2" of drop on the fronts.
It's been three and a half years since I did it, I'm afraid I don't remember which end I cut.
Billiumss
06-20-2006, 04:54 AM
Do you have the same springs I have?
Caswell
06-20-2006, 05:07 AM
I've got whatever Eibach springs came with the old SLP Level 1 suspension kit. I'd assume they're the same SLP Eibach springs you're talking about.
trackbird
06-20-2006, 01:00 PM
You'd have to cut the bottom. It will fit in the perch, but it will not have the extra coil on the bottom to stabilize it. Let me look at a spare set I have and see if it looks like we can cut them and get what we want out of them and still get them on the perch.
Billiumss
06-20-2006, 08:03 PM
Thanks Kevin, I want to get this done this summer/fall.
casey02ws6
06-20-2006, 09:06 PM
Just put the turbo kit on it. The extra weight will bring it down :devil:
trackbird
06-21-2006, 08:17 AM
I thought that was the idea (turbo). Change of plans?
Billiumss
06-21-2006, 09:50 AM
I keep going back and forth now, Turbo Kit or Big Cubes.
As of right now, Big Cubes. It's cheaper, easier and I can spray a 150-200 shot on top of it as needed.
trackbird
06-21-2006, 10:00 AM
Well, I did drive a 510+ RWHP SS with a 402 LS2 in it this week. It's not a bad way to go.
SLIKWS6
06-21-2006, 08:12 PM
What did you guys use to cut the spring? Thanks.
trackbird
06-22-2006, 12:37 AM
Nothing yet, but I have a chop saw at home and I know it will do the job with a bit of work.
02pewterform
04-14-2011, 11:38 PM
Old thread but I am thinking about cutting my fronts this weekend and was wondering if anyone ever did this. If so how much did you cut and how is the ride.
