twin turbo work in progress pics
here is the pics showing my headers for my twin setup..
its as cose to equal length as i can get.. also the priamaries enter the collector in the right order...
the other one will be a mirror image except the one jogged tube by the collector will go straight in and the rear tube will go to the other side.. this will keep them in order as it fires in a diffrent order on the passenger side..
Originally Posted by Beaflag VonRathburg
Those are really nice headers. What sort of vehicle is all this going into, what turbos? We need more details.
lt1 camaro
oh and things are looking good!
2X Innovative 60-1 hifi, 0.81 ar p trim exhaust, big shaft, heavy duty backing plate
1 3/4" primares
95 lt1 camaro
going to have 9:1 383 stroker
as soon as i can get some cash for better heads it will be 8.5:1
1 3/4" primares
95 lt1 camaro
it will retain stock rad, ac, and the abs will be relocated.
ac will be mounted on the driver side head up high like the alt.. the belt will go right across the tb.. you wont want to reach in the engine compatrment to crack the throttle with this running... lol i might make a 2 pc gaurd at work to cover up the belt so no one touches it while its running
it will have dual 3" down pipes both will run out of the passenger side.. one under the header and one where the ac used to be.
actually it will have dual 3" exhaust front to back. with dual 3" cats and possibly no mufflers. i dont know how loud that would be at low throttle.
