Video of me trying to launch my M6
Ok, Im trying to get my 60 ft times down, The best 60 I have done is a 1.7. I of course missed the shift on that run The car is an almost full weight Formula m6 with the cheatr cam, patriot heads, and 100 shot. Its running 12.3@113 n/a and 11.5@124 with the n20. 60fts are 1.8s and 1.9s usually with an occasional 1.7x. I think the car could be a little faster if I could get the launch right. Suspension is mostly stock. Front sway bar is removed.Tires are ET Streets (bias ply). The car either bogs or spins em. I cant get that magical 1.6 or 1.5 60 ft,
I have UMI adjustable poly/rod end LCAs,Panhard rod, and relo-brackets at home waiting to be installed and Hal shocks front and rear with the 275 lb springs up front on order. (On the advice of Tosto who I think knows a thing or 2 about launching a M6)Hopefully this stuff will get me where I want to be, but I figured I'd throw this vid out of last time at the track in case someone could point out something Im doing wrong. My best launch(1.7x) was against that import, but then I missed a shift.
I think I need the driver mod
Vid is here: http://video.ls1tech.com/video/66509...ba0c0776a1.htm
what tire pressure are you running, you should start out at 15psi and if you spin then lower them.
what are you launching at?
this is how i launch! maybe you could try this.
http://smg.photobucket.com/albums/v2...t=DSCF3073.flv
http://smg.photobucket.com/albums/v2...t=DSCF3058.flv
i rev higher as each light comes down, reving higher until the third light when i rev it up to 5500 and dump it.
-brandon
-brandon
-brandon
-brandon
Nice runs BTW.
heat those ******* up better and you should hook better. good amount of white smoke should do it.
plant that bitch right at 6k and let it spin for about 5-8 seconds till you see a nice cloud. then they are heated up. your 60's will improve a lot
steve
steve
Originally Posted by 396D1SS
what kind of rear are you running?
Originally Posted by Sgt. Spuds
God damn man, your car looks like a SCREAMER. getting down teh track just fine if you ask me lol.
Hey man
You need to put a line lock in the car and heat those tires up alot more.
2nd gear burnout up to 6000rpm and hold it for at least 4-5 seconds after smoke appears. Run 11psi cold in the tires.
You'll drop a TON in the sixty. Launch at ~5000-5500rpm and on the third light floor the gas while lifting straight up off the clutch as fast as you can.
You will **** you pants at the difference it makes
Originally Posted by CHRISPY
Hey man
