Which Intercooler Size should I use ?
Hi,
Builbing up a single turbo LS1 T70 turbo, forged 346, plan to run up to 12- 14 psi.
Can either squeese a 600x300x75 or a 500x300x100 which shoul I go for /
Cheers
John
Cheers
John
Coal Mining Director
The bigger the better since we are size limited. I would put the largest horizontal flow IC in for a single turbo install. Horizontal flow will have better thermal eff. Vertical flow will have less pressure drop, but will not remove the heat as well.
