F1C/F1R Procharger Guys...
What size pulley are you guys running on built 408s? I have a 3.85" pulley and a 4.25" pulley sitting here to match up to my 7.65" crank pulley. I am wondering what kind of power you guys are seeing with different pulley setups? Also boost numbers as well.
I will have a built 408 9.0:1 compression with ET240cc heads and 1 7/8" headers mounted up. I am just trying to gauge which pulley I should use. I iintend to spin the motor to 6500-6800RPMs. I also upgraded to a much larger intercooler. And for reference I will be running an F1C head unit.
Thanks for the help.
PS: Stock 346 bottom end with stock heads and a blower cam on the F1C is insane only pulling to 5k RPMs making 12-13psi depending on the day. Its just on a really rich tune. I only swapped the blower on to test fitment and found a buyer for my D1SC so I still have this thing on and driving around town with this thing is insane! I can only imagine what it will feel like with the new bottom end and heads along with 6500RPMs... w00t! I am stoked!
Also... I currently have an LS6 Intake Manifold, but was wondering if I should upgrade to a FAST 90 IM with a NW ported TB to match? Would I see any gains from that or should I just skip that and get a Victor Jr? If you suggest the Victor Jr, please let me know where I can pick up all the necessary parts to make it work.
Thanks again
Thanks again
SSU Moderator
I think Speed Inc busted a FAST 90 under boost.
Don't know if a Victor will clear the hood of a GTO.
Is this a custom bracket? Where did you get it? Also, what are the specs for an F1C? F1 is like 1500cfm, F1R is like 2000. Is the C in the middle?
9.75" Volute
74,000 rpm redline
5.73 to 1 gear ratio (may be a variable depending on when the unit was built)
Originally Posted by andereck
F-1C 1850 CFM
9.75" Volute
74,000 rpm redline
9.75" Volute
74,000 rpm redline
Mick, the ATI crank pulley for the GTO is only 7", not 7.65". Just FYI.
Ron (b727pic) verified it and is looking for a larger one to be made.
http://www.ls1gto.com/forums/showthread.php?t=78170
One alternative solution would be to machine a 2.24" spacer on a lathe and use the LS1 F-body 8 rib 7.65" race pulley with the spacer. Many shops could handle this.
An aftermarket balancer on the GTO would be a must with this setup.
Depth of GTO fluidampr pulley overall 3.45"
Depth of LS1-Fbody pulley including rear recess 1.21"
Do not machine parts without verifying actual measurements first with parts in hand. This is a quickie with a dubious set of calipers.
ATI LS1-Fbody race crank pulley part number DC017A-008 retail $157
Hey Mick go with the Vic Jr. cuz Ive done a good amount of search on it and like it a lot for boost. As for the intake elbow that fits the Vic Jr, call Nitrous Dave. They have a low profile elbow that will clear our hoods.
http://www.nitrousoutlet.com/installs/install.asp?id=22
