NEW high volume oil pump
I have been told by a somewhat knowledgeable friend that this GM performance part oil pump out-flows an LS6 pump. He said it has never been used in a production car, just sold as a performance or replacement part.
I am just a little sketch becasue all I hear about on here are the ported ls6 oil pumps. It is supposed to be a high flow pump of some sort.
Check it out: http://www.sdpc2000.com/catalog/4460...es-Engines.htm
On a stock oil pan on an f-body, a ported and shimmed LS6 pump is likely pushing the limits of sucking the pan dry. Anything more such as this pump will need an aftermarket pan.
Jason
Jason
Jason
Jason
****. SO much for saving $60 and going with this pump instead of an ls6. H/C swaps blow.....for my wallet at least.
Anyone else actually USE this?
Originally Posted by ninetres
Damn....so you heard it out flows a ported ls6????
Jason
If it's the same thing as the Melling Thunder sells, I wouldn't want to chance it on a stock 5.5 quart f-body pan. http://www.thunderracing.com/catalog...&vid=3&pcid=83 I may be wrong, but I wouldn't be surprised if this thing flows more then a ported LS6/stock pump.
Jason
Jason
But I doubt thats the same one. I couldn't imagine thunder charging over twice as much for the same part.
He said it is a GM performace part and FINE to use with a stock oil pan....that is what it is designed for.
i've thought about starving the motor for oil due to a pump that works TOO well...so it lead me to searching and reading that it's ok to run the f-bods 1 quart over full to ensure this doesn't happen? evidently some guys that road race (with corvettes, too) have been doing it for awhile. any other input?
sorry dude, not trying to hijack your thread!
Originally Posted by s346k
did you ask including that some ppl will use this oil pump mainly in operation between 5,500-7k?
We all know the nickel and dime stuff for a H/C swap really starts to add up.
I didn't specify the RPM band. I would just hate to spend another $70ish dollars for a ported ls6....when this one will do just fine.
I've got a ported LS6 I can sell you for 70 shipped, was ported by alan futral. CAme out of my shortblock with 58k miles on the shortblock... 4 k on the pump. was making over 50 lbs at idle and a good bit over 60 full.
PM me if you'd like it.
