Drag Racing Tech
Rear swaybar upgrade....I did search
Old 06-20-2006, 06:25 AM
DarkFormula's Avatar
Default Rear swaybar upgrade....I did search
I've heard that there are advantages from launching/traction by running a bigger rear swaybar in our cars. I believe stock to be 19mm, and I have the chance to pick up a nice 24mm piece for a good price, with poly bushings.
Can someone elaborate for me? Will this really improve off-the-line traction, and will this improve handling to boot?
A search yielded vague or no results. Thanks!
Old 06-20-2006, 09:46 AM
rocketman442's Avatar
I got one off of a older (90) WS6 formula, it was 21mm I belive and it was free, my car launched striaght before but wasn't all that fast. I haven't been able to run it on stick tires yet to see if it still does. It did improve handling in my opinion also.
Old 06-20-2006, 12:18 PM
FloydSummerOf68's Avatar
The faster your car is the more it will help. If you're running a 14 second ET then it wont help as much as if you're running 11's.
The stiffer rear sway eliminates any roll in the rear and allows for a harder/straighter launch for the rear.
Old 06-20-2006, 02:13 PM
That's what I'm looking for. The car hits hard on the launch, and although an airbag would probably help, it likes to nose to the left. I could probably do well with upgrading my BMR PHR to one of their adjustable ones.
Thanks
Old 06-20-2006, 02:28 PM
I'm pretty sure the only reason for a adjustable PHR is to center the rear under the car if your lowered.
Old 06-20-2006, 02:36 PM
You're right, adjustable PHRs are mostly for lowered cars.
Old 06-22-2006, 10:07 PM
bad6as's Avatar
would it help or hurt handeling
the bigger bar i mean
Old 06-22-2006, 10:17 PM
A larger rear bar will make your car lean more into oversteer due to the fact that its much stiffer and has less give around corners.
Old 06-22-2006, 10:18 PM
bad6as's Avatar
and overster is...describe it
Old 06-22-2006, 10:37 PM
Your *** end swings out.
Old 06-23-2006, 07:19 AM
tektrans's Avatar
I just got the Spohn Drag bar. I tested it out on wed night and it worked great. I got a nice wheels up launch and some guy told me later my front tires were about 3 ft up. Straight as can be too.
