? Inside....P0106 MAP/BARO CKT???
Old 06-20-2006, 10:07 AM
BadAzz96Z28's Avatar
Default ? Inside....P0106 MAP/BARO CKT???
I have recently started getting this code pop up here and there and wonder what it is/means...
"P0106 MAP/BARO CKT Range/Perf"
It is a cam-only car and it was running fine for 1-1 1/2 yr's w/o any SES lights at all and now this comes on/goes off quit often. I replaced the MAP sensor and I dont know If that was the problem or not b/c it still comes on. Anyone have insight for me on this? Thanks in advance
Old 06-20-2006, 06:17 PM
no thoughts???
Old 06-20-2006, 09:24 PM
technical's Avatar
When all else fails...
http://www.gearchatter.com/viewtopic9390.php
Old 06-22-2006, 02:38 AM
35th SS's Avatar
check for vac. leaks in front and back of your intake.if no leaks raise your idle just a bit.good luck.p0106-low vac.@idle. threw this code on my 35th after the h/c install.
Old 06-22-2006, 12:34 PM
Thanks Alot...thats probally the problem. Will this code cause any timing pulled, fuel added/removed, any other tunning issues? I recently dropped the idle a little so I could hear a better lope from the cam and thats probally it.
Old 06-22-2006, 02:56 PM
technical's Avatar
Not to break you stones, but your first post stated the car ran fine for over a year. Then you just said that you recently made a change. Next time, let us know in the first post.
Old 06-22-2006, 04:10 PM
I did not think about dropping the idle 50 rmp's when I made the post. Slipped my mind.....It ran fine for a couple months after that was done and then started throwing SES .....May be the idle to low, may not ....dont know yet
Old 06-23-2006, 12:48 AM
35th SS's Avatar
Im not sure about the other ?s you mentioned but I doubt it.I would bet this is your problem.idle too low cause you to throw that code.
Old 06-23-2006, 12:58 PM
technical's Avatar
That happens. What is the MAP reading at idle and what do you have the idle set to?
Quick Reply: ? Inside....P0106 MAP/BARO CKT???
