HP Evo 18x9 front & back
Old 06-20-2006, 11:05 AM
DMark's Avatar
Question HP Evo 18x9 front & back
Looking for advice from those of you who are running HP Evos in 18x9 both front & back.
Will 275/35/18 tires work on the fronts? Any rubbing issues?
Thanks,
DMark
Old 06-20-2006, 11:50 AM
2000taws6's Avatar
That is the perfect size for front and rear. You can rotate them and they wont rub.
Old 06-20-2006, 12:14 PM
DMark's Avatar
I would think that also since the 275/35/18s are almost the same in size as the 275/40/17s used on the WS6 cars.
I'm asking because TireRack and others recommend running 18x8 in the front with 245/40/18s.
Thanks for the reply..., anybody else have any experience with 18x9s all the way around?
DMark
Old 06-20-2006, 01:01 PM
FH212's Avatar
I run 18x9 HP evos on mine with 275/35/18's on all 4 corners.looks better,no rubbing no fitment issues whatsoever.
Old 06-20-2006, 01:15 PM
Modified's Avatar
Default No rubbing on my HP Evos....
I'm running 245/40/18 on all four corners becuase it is the same height as my factory rims.
Attached Thumbnails HP Evo 18x9 front & back-dsc00684.jpe
Old 06-20-2006, 01:19 PM
DMark's Avatar
Are those on 18x9s?
DMark
Old 06-20-2006, 01:49 PM
Xsta Z 28's Avatar
18" x 9" wheels with a 275/35ZR18 is a PERFECT fit. Same OD as stock.
But so is a 18" x 8" with a 254/40ZR18 . . . .
Old 06-20-2006, 01:53 PM
Modified's Avatar
18x9.5"
Old 06-20-2006, 02:17 PM
DMark's Avatar
18x9.5"
Are they HPs? I understood that they only went to 18x9.
DMark
Old 06-20-2006, 09:30 PM
Modified's Avatar
Default got me?
The guy I got them rims from said they were 18x9.5" When I check web sites I only see them 9.5" on 19" rims. I ran a tape measure through it at and it come up 9.5". I know that is not the most accurate way to measure them, but it's the best I got right now. I measured it from where it rolls in on both sides(like Summit Racing catalog says how to measure).
I know it doesn't help much........sorry.
Old 06-21-2006, 12:28 AM
FLAWLS1T/A's Avatar
first of all you can only get 18" rims with a width of 9 inches, the 19's you can get 9.5 inches width
Modified, you cannot measure a rim like that, thats why your reading is incorrect.
With a 18X9 inch rim go with a 275 or 285!
Old 06-21-2006, 06:36 AM
Modified's Avatar
Yea, I figured my measuring was off.
Old 06-21-2006, 12:48 PM
DMark's Avatar
Question
FLAWLS1T/A,
Those rims look great but..., what size tires are those? They don't look to be 275 or 285.
DMark
[/QUOTE]
Old 02-26-2007, 04:47 AM
JasonWW's Avatar
Originally Posted by DMark
FLAWLS1T/A,
What were these old tire sizes?
Looks like you have new tires now and it looks much better. What size are the new ones?
Old 02-26-2007, 08:02 AM
big reg's Avatar
I have 19x9.5 HP Racing HPR5's on all four corners on my car with 275/30/19 tires. I have no rubbing issues at all and the car is lowered as well. The only problem i have is the 19" 275's were substantially narrower than my old 275/40/17 KDW's.
I might step up to 285's with the 19's to offset it. Has anyone else noticed this with larger diameter tires in regards to width?
Old 02-26-2007, 08:11 AM
JasonWW's Avatar
It might just be a difference in the brands.
Old 03-01-2007, 09:23 PM
JasonWW's Avatar
Nevermind, I think the skinny one's were 255/30/19, right? Now you have 275/30/19.
