Hp tuners?
Old 06-21-2006, 06:13 PM
00ws6blackbird's Avatar
Default Hp tuners?
Im thinking about getting my t/a tuned by a performance shop. The cars is pretty mild though with it just having headers and dual exhaust. They said they would charge $350 for dyno and tune. Is this worth it? How much horsepower can I expect and will throttle response be better?.....Thanks
Old 06-21-2006, 06:49 PM
soundengineer's Avatar
for a header and exhaust tune they will be rippingyou off at $350..
I am not a sponsor..but I do tunes locally thru severl local boards for that for full cam and heads..adn come out with a better tune than ust doing a pull on a dyno...
they are going to push your A/F around with 1 table instead of the others that are really responsible for fueling..adn when you get to the street its going to be lean cause you can simulate the characteristics of aiflow on the street/track
I use the dyno..but I use it to find an A/F spark combo..and then I dial in real A/F on the street with a wideband in the exhaust pipes..
you should definately try totalk them down from $350 for a headers/exhaust car that shouldnt cost as much as a heads cam car..
and it will only change your WOT stuff....
you can gain a lot more from a proper street tune especially down low...plus some spark adjustment to help it as well...
shame you are in texas..LOL I dont know anybody or any forums down there that you could ask some more questoins on..
Old 06-21-2006, 08:07 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
What year model F-body do you have and where are you located in Texas? Scanning the car will tell you how far off the tune is.
Old 06-21-2006, 09:32 PM
My car is an 00' and I live in Amarillo
Old 06-21-2006, 09:47 PM
TXCAMSS's Avatar
Ouch. That's way out there.
If you are ever in the Houston area, I'll scan the car for ya.
You may want to ask around for some local guys that might be willing. Good luck!
Old 06-21-2006, 09:53 PM
Yeah...not too much around Amarillo..Lol.....Thanks for the offer
Old 06-22-2006, 05:39 PM
Any idea on how many tenths a good tune will take off in the 1/4?
Old 06-22-2006, 07:26 PM
TXCAMSS's Avatar
If you have an A4, it's good for a noticable difference. The ET improvement is hard to calculate since the mods will vary from car to car. An A4 could see a tenth and a half with TM removed, fueling lined out right and some added timing. I hope that helps. Good luck!
Old 06-22-2006, 10:47 PM
I've neted people as much as half a second with a good tune vs teh tune they used to haev that wa a dyno only tune
Old 06-23-2006, 09:52 AM
cool....i guess im in need for a good tune then
Old 06-27-2006, 02:38 PM
Finally got the car tuned.....30 rwhp gain ....Car is still running a little rich....started out with the a/f at about 9.5 or so and they only got to about 10-10.25....they said when they tried to lean it out, more oil than fuel was there because the rings are getting bad. They also said that someone tried to tune it before and had it too rich. The car has almost 90,000 miles.
Old 06-27-2006, 03:13 PM
if they only got you to 10AFR then you should ask for your money back or ask for a real tune...
you need to be in the 12.5-13.0 range
tell the shop experienced tuners are saying they are dumbasses..
ls1's go for 250,000 miles with no issues..I have a buddy that just turned 280,000 miles...yes....a lot of highway travel driving for him...
he's replaced a few things for safety reasons..but its the stock rings and pistons...
I'm at 93,000 on my car..adn have no issues getting the A/F correct...
that shop just doesnt know what they are doing of they cant get there from here...
if you do a compression check(after the engine is hot) you can see how good or bad the rings are getting...if you still have good compression then you shouldnt have any issues...
a leakdown test can also show you how much wear and tear you have from varius parts of the engine as well
Old 06-27-2006, 07:54 PM
When I say 9.5, that is where it is at about 5500 rpms. The a/f at lower rpms(3-3700) is anywhere from 12.4 to 13.1. I plan on doing a compression test..just to check.
