Wut happened to my fans?
Ok, I have a 93' LT A4 and i'm to rigging everything i can and i came up with a bright idea to make my own fan switch with just a toggle switch and wires. So, i cut the two wires (Blue and Brown) cuming outta the first fan and tried my rig job and it didnt work. so i thought o well no big deal just reconnect the wires the way they were and i'll b good to go, WRONG. I reconnected them and now my fans dont turn on at all and the temp redlining bout 260. If anybody kno's how i can fix this please any input. THNX, Nate.
if you cut the wires while the battery was still connected you possibly could have blown fuse or jacked a relay, like he said I would check both those and if it doesnt work good luck, I hate electrical problems
You'll have to put a toggle hot wire on the relay switch to turn the fans on. Find out which wire turns the the fan on through the relay, (should be a green or blue wire) and put your toggle hot wire in its spot. If you have any other questions ask
