Anyone mash together headgaskets like import guys?
Are you sure you are not referring to the Hondata (or copycat) gasket between the IM and head? They are about a 1/4" thick and a polymer material.
They are supposividly proven to lower Intake temperatures.
I had one on my old prelude. Not sure about gasket stacking though. Sounds leaky to me.
between his heads and block to lower compression
I like the term squish better, but when talking about piston engines they both refer to the same thing. In a modern Chevy motor, both the piston and the head have some areas that are flat. In the most modern motors, the flat areas on the combustion side of the head have their patterns matched on the tops of their pistons. When the piston moves up in the compression stroke, these flats areas are specc'd to come within .058" - .035" with steel rods and forged pistons. The gasses stuck between the 2 flat areas are "squished" out into the combustion chamber, tumbling and very fast. The squished mixture meeting the induction mixture swirl like crazy when they meet, and help even out the mixture throughout the chamber, which leads to better combustion and less tendency to detonate.
This is why you don't see serious people solving their compression problem with double gaskets, you see them lower the compression properly through dished pistons, or changing to larger chamber heads, or using meth or putting on a big FMIC to keep combustion temps down.
Don't mess with the quench areas.
Jim
id do it in the pistons and heads! easier safer and tried and tested! dont get me worng the Honda thing works, and i have seen it used on other motors to (not sure if they are using new longer liners, or running the piston into the plate area thoguh!!).
you would have to think about push rods to!
thanks Chris.
thanks Chris.
hang on gasket is not as strong as liner and block. so why are people using gaskets (weak) to redyuce compresion when a set of forged (strong) pistons would get the same results and be safer?????
Chris.
Chris.
