Help me set up my TC lockup tables on HP tuner software?
I'm having problems with my converter wanting to lockup at WOT from 1-2nd shift at the track. It falls flat on it's face through 2nd gear then around 4000 rpms it will unlock and run fine from there. How would you setup the lockup?
PT 4400 stall/4.10 gears/26 in tall tire/Trex cam
Moderator
That's mighty abnormal, I've not seen any 2nd-
gear lockup tunes (my stock had all 255 MPH for
the 2nd gear lockup row). As in, "not this week".
It might be there is something else going on like
the trans getting into a bind, apply before release
or something like that. Watch TCC Mode and see
if you can detect an attempted lock. You'll have to
look at it in the table view as you scroll through
the logs, you can't plot "Locked" on a numeric
graph.
graph.
