Engine shaking on cammed cars
Old 06-22-2006, 07:05 PM
Xtnct00WS6's Avatar
Default Engine shaking on cammed cars
How bad does your engine shake? I have a TR 224 and my engine shakes more than I think it should. Maybe my engine mounts are toast? Can this be tuned out through the computer?
Old 06-22-2006, 07:14 PM
z28convert's Avatar
i have a 232/238 cam. it shakes sometimes....but i like it, im sure you could tune it out
Old 06-22-2006, 08:07 PM
Randy WS6's Avatar
I put a T-REX in my car with stock motor mounts and it shock the doors off,I put Pro Thaine motor mount in, now very ,very little shaking.
Old 06-22-2006, 08:09 PM
Doomsday's Avatar
My shakes a bit more at warm up.
Old 06-22-2006, 08:17 PM
DWillTA's Avatar
My 232/234 comp cams with Prothane mounts shakes very little. It gives you some vibration idling thru the whole vehicle but the engine itself moves very little.
850 idle M6.
Dave
Old 06-22-2006, 08:22 PM
Quik's Avatar
at stop lights i can feel the whole truck shaking with the TV2. im going with a torque strap to help aid in that along with helping transfer power better
Old 06-22-2006, 08:25 PM
brad8266's Avatar
My stock cam car was shaking too until I put poly engine mounts in a month ago. No more shaking now.
Old 06-22-2006, 10:27 PM
REDWS6ROCKET's Avatar
yes they will shake that is part of putting a cam in, i have poly mounts and mine has little to no shake to it with the trex!
Old 06-22-2006, 11:21 PM
MountainMotor's Avatar
Yea, mine shakes too with the TR224 so I've been looking into some new motor mounts.
Old 06-22-2006, 11:24 PM
Turo's Avatar
I have an F13 and the car doesn't shake too bad, but when you pop teh hood you can see the motor rocking side to side. I'm on stock motor mounts.
Old 06-23-2006, 12:04 AM
Joel_SS's Avatar
Yep mine shakes to. Stock mounts.
Old 06-23-2006, 12:37 AM
chewy99ws6's Avatar
mine shakes a little, but not enough to bother me.
Old 06-23-2006, 02:00 AM
Patrick B's Avatar
Where are you guys getting the poly motor mounts, and how much?
Old 06-23-2006, 02:04 AM
Studytime's Avatar
Thunder. I think they're around $50 or so. It's on the site... thunderracing.com
Ben T.
Old 06-23-2006, 02:08 AM
Patrick B's Avatar
Thanks
Old 06-23-2006, 07:56 AM
Demon SS's Avatar
the shaking is due to the **** stock engine mounts, it is always a good idea to change mounts when doing a cam swap. most folks don't but it is a good idea.
the rocking/shaking is NOT a good thing- think of it this way, if the engine is moving it takes power to move it, that power is not getting to the wheels(might not be much but..), more importantly with significant movement of the engine your drive train is being put in a bind and premature failure can result. Just my .02
Old 06-23-2006, 08:05 AM
treysoucie's Avatar
mine shakes like a biotch... and worse when i turn the a/c on.... makes rattling/knocking noises too... i definatley need poly motor/tranny mounts, and a decent tune
Old 06-23-2006, 08:13 AM
WS6WRX's Avatar
yep, stock motor mounts suck w/ a cam. I suspect that is what caused my a/c line to break.... sucks.
Old 06-23-2006, 02:58 PM
jmm98LS1's Avatar
After my cam swap my motor would move nearly and inch in either direction at idle! My stock mounts were toast....it's pretty solid now after poly motor mounts.
Old 06-23-2006, 03:02 PM
1sick'98WS6's Avatar
how long would it take to swap out the motor mounts? and how hard is it
Quick Reply: Engine shaking on cammed cars
