4l60e
Sorry to say guys that the vet case is unique to corvette's only. It has a seal in the rear of the case to seal the output shaft and doesn't use a tail housing. The trans splines directly into the rear differential which has a seal as well. If you take and put this trans into an f-body,truck,etc there wiil not be any lube for the drive shaft slip yoke to tail housing bushing.
