Procharger question
Procharger question
Hi,
I dont knot that much about prochargers, did they used to make ones that had oil lines running to the? I know all the new ones are self contained, ut was wondering, I found one on ebay pretty cheap, and it has an oil line running to it, will the bolt pattern be different on this than the current series D1?
i guess the main question is, will it bolt into the current D1 bracket?
Thanks
Ed
Thanks
Ed
ATI still sells both self contained head units, as well as the head units that require an oil line to the engine. The SC at the end of the part number stands for self contained. I have no idea if the bolt pattern would be the same on the one you are looking at, as the current models. How old is the unit? Bob
The oil fed blowers take a different bracket than the SC or F series blowers. The brackets for the P600B and D series blowers should still be available from ATI for older applications that they were made for. They are not available for LSx engines however. You can get the serial number of the blower from the seller and then call ATI for any history on the unit.
ATI Technical Service 913-338-2886
