bent pushrod - 2 in a row same cyl??
I tested/tuned my car beat it pretty good and everything was fine. Then yesterday I started getting into it 4500rpms (aprox) bent a pushrod INT #7
replaced it. took it out again, same thing, INT #7. And both pushrods are bent the exact same, mirror images of each other.
Its a Stock cam 5.3 bigger springs though, forgot specs. I know the stock pushrods are weak and thats what I have for now. But what would make one specific cyl act this way? any ideas? or is just a stupid coincedence? I'll try for 3 in a row.
I dont know if this is the wrong forum, but its a turbo application so??
you should replace the spring on that cylinder. if you don't want to replace it move the intake spring to the exhaust spring. but to be safe i'd just replace it. it could be just a weak spring.
