loudmouth
Re: loudmouth
i know the sounds you are talking about. i have an 02 z with the lm, but mine only makes those sounds when its cold. is yours all the time?
loudmouth
I have a 98ss with the m6. I put the slp loudmouth on it. I like the sound of it but would like to get rid of the popping, backfiring on the downshift. Does anyone have any comments or videos or sound clips? I was thinking the dynomax bullet or the borla xr1 . I dont care about cost. I want the best sound. I still want it to sound mean as hell.
Thanks
sweet98ss
Thanks
sweet98ss
Re: loudmouth
the bullet muffler is the way to go for price. I think that the borla sounds better but more $$$.
also 2 flowmaster race mufflers right before the tips could work as well.
Re: loudmouth
It's normal for manuals. My friend has an '02 Firehawk and his does it when he downshifts. The bullet muffler should help. <img border="0" title="" alt="[Smile]" src="gr_stretch.gif" />
<small>[ April 22, 2003, 09:42 AM: Message edited by: SiggyBaby ]</small>
Re: loudmouth
I have the lm on my 02 z auto and it doesnt really backfire just sounds mean as hell.I like it alot.I have on order GTP stage 2 heads MTI X1 cam and my headers should be here soon-Hooker with off y.I will switch the resonator to two bullet muffs when I get the cam installed.You can pick them up fairly cheap at meineke.
Re: loudmouth
This may sound like a stupid question, but why do you need to down shift all the time? Is it during a panic stop? All you accomplish by down shifting is excessive wear and tear on your shifter, clutch, pressure plate, engine rings, basically your whole drive train. When I see that I'm going to have to stop ahead I just drop her into neutral and start coasting and then use the brakes to bring her to a stop. Brake pads are alot cheaper and easier to replace than the aforementioned components. It might have sounded cool with your stock exhaust but now that you have the Loudmouth just stop downshifting. Problem solved and it won't cost you a penny. Try it, you'll like it. <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
<small>[ April 24, 2003, 09:20 AM: Message edited by: Drainplug ]</small>
Re: loudmouth
Right, but you should be able to up your rpm's without having to drag down the engine first.Push in the clutch as you're raising the R's with the gas pedal and shifting to the next lower gear in one smooth motion. Sorry if I make it sound so easy but I'm just an old Fart that's been driving a stick shift for 41 years, it'll come to you eventually.
<small>[ April 24, 2003, 09:31 AM: Message edited by: Drainplug ]</small>
Re: loudmouth
</font><blockquote><font size="1" face="Verdana, Helvetica, sans-serif">quote:</font><hr /><font size="2" face="Verdana, Helvetica, sans-serif">Originally posted by Drainplug:
<strong> Right, but you should be able to up your rpm's without having to drag down the engine first.Push in the clutch as you're raising the R's with the gas pedal and shifting to the next lower gear in one smooth motion. Sorry if I make it sound so easy but I'm just an old Fart that's been driving a stick shift for 41 years, it'll come to you eventually. </strong></font><hr /></blockquote><font size="2" face="Verdana, Helvetica, sans-serif">Very sound advice. The LM tends to pop and backfire (especially when cold) whenever you are running it a little hard. I would upshift, and it would sorta pop. I think it has to do with the resinator having nothing in it. At least a Bullet has some packing to absorb the small backfires. I just drove and enjoyed the sounds. If you leave it in gear to decel and its cold it will backfire like a ****. With LT's and ORY it will occassionally spit fire. <img border="0" alt="[evil]" title="" src="graemlins/gr_devil.gif" />
<small>[ April 24, 2003, 09:40 AM: Message edited by: SSCamaro99_3 ]</small>
Re: loudmouth
I can't speak to my loudmouth popping when cold because I've never driven it when it wasn't thoroughly warmed up to operating temperature. I can say that it backs off very sweetly for the millisecond that I'm between gears during accelleration. <img border="0" alt="[USA]" title="" src="graemlins/patriot.gif" />
