p0300
Old 06-25-2006, 10:06 PM
purple98haz28's Avatar
Default p0300
i get a code for p0300- random multiple misfires. sometimes the car will bog then will unbog like a buton was pushed. it is very weird. i am going to look at the plugs and wires asap. what are your guys ideas as to mu problems
Old 06-26-2006, 06:29 AM
come on sombody must be able to help
Old 06-26-2006, 07:02 AM
227Hawk's Avatar
You're most likely on the right track. Random misfire code.
Hawk
Old 06-26-2006, 07:17 AM
CHEVYMAN434's Avatar
Default P0300
Well,i had the same problem after a 3600 converter install.Started right away.The engine really does not have a miss in it but just gets this ghost reading from somewhere.I just hade my tuner delete this code.
Old 07-14-2006, 11:39 AM
aNuBiS's Avatar
i seriously would NOT have had that code removed...lol
Old 07-15-2006, 07:22 PM
gillbot's Avatar
What tuning software are you using?
Old 07-16-2006, 04:39 AM
98A4LS1's Avatar
Is the engine stock?
To the other poster I wouldn't run with the code deleted, could be a mechanical problem.
Old 07-17-2006, 03:41 PM
wait4me's Avatar
probably just bad plugs or wires..
Old 07-17-2006, 04:36 PM
aNuBiS's Avatar
What Im getting at is, sure it could be somethign simple THIS time. But the existance of the code is for a reason. So next time your engine is near ready to explode you'll be none the wiser cause you eliminated the code
Old 07-17-2006, 04:38 PM
wait4me's Avatar
I agree not to remove that code, But it does need to have the tables modified to make them better tuned for your engine modifications. OR you will have false missfire codes.
Old 07-17-2006, 09:40 PM
227Hawk's Avatar
Change the parameters.................
Most people won't help with this. Thats why it's easier to delete/turn the
PCM codes off.
Hawk
Old 07-17-2006, 09:45 PM
wait4me's Avatar
Most of the time it is common sense on what to do. I do understand what you are saying. It is very hard to get answers, "and correct ones" alot of times on the forums. Eventually it does get answered.
As for your way of setting up for misfire detection. Usually on a heads and cam car, i start out with an ls6 table set for the perameters, Then, i add 10% that usually gets it really close, Then ill drive the car in lots of low rpm situations and see if it hits any, if it does, then all you do is add 10 more percent, Only in the low rpm tables are they needed to be modified. Then, i have a plug wire that is bad that i have saved, i use that as a tester plug wire to see if the computer will still catch the misfire. then im done.
Old 07-17-2006, 09:48 PM
aNuBiS's Avatar
Im replying in this thread, because Im in the same boat right now. I got a p0300 code after a heads/injectors/pulley install and Ive modified the injector tables but still shows the code. Then after awhile of it being on it starts to flash.
Ive had HPTuners on it, and a SnapOn scan tool and they both show missfires in all cylinders. Not sure where to go from here. Plugs are newly put in, and dont look in bad shape.
Old 07-17-2006, 10:12 PM
wait4me's Avatar
The correct tables to modify are:
C5621, and C5622.
Also make sure that C5625 is fully maxed out.
