Injectors... and stock vs Disc
Injectors... and pintle vs Disc
if anyone has run into problems tuning disc injectors try modifying the IFR of course to get them to work(main table for installing new injectors and getting them to work,
but if you recently installed injectors and you are getting codes change the Injector Pulse width voltage adjustment by about -10% to -15%(depending) (table b3701 in EFI LIVE) and in HPTuners its the injector offset, vs volts versus manifold pressure (Kpa)
Might want to rephrase your title... the two styles of injectors are pintle and disc.
This table helps when you can't get your fuel trims in line at idle or high vacuum situations, and you've already got your IFR table right.
