fast 90/90 with 224 cam...
i was wondering if getting the fast 90/90 setup would be worth it on a cam only car with all the bolt ons and a 224 cam or should i just stick with the ls6/ported tb? and also my i pipe on my exhaust is 2 3/4, would i pick anything going to a 3 in pipe? thank you
Moderator
With a bigger cam and a good set of heads the 90/90 set up can be worth 20rwhp or more. It would kill the low end on a small cam like the 224. Plus you would probably not gain anything over an ls6 or fast 78.
what about on a set of ported 62cc 243's and a 224/228? Any good then?
Port or not to port the intake?
I have a stroker and was wondering if its necessary to port the intake at all to get the best bang for the buck with this 90/90 setup. Got the 90/90intake and TB in the garage now. Been told the "out of the box" intake anit worth much at all....true?
Is porting worth it? I want MORE low end torque.
