Shakedowns made. New best and new bugs.
See here. Posted in 11s section. What do you all think?
https://ls1tech.com/forums/11-second-club/531794-made-but-s-time-work-out-bugs.html
Race your car!
Get those brackets welded up better. Also, are the control arms on your car rod ended stuff, or bushing units? If they aren't rod ended units, I wonder of the bushings are causing some distortion. Also, could be tire groth down track causing the rub.. that happened on my car last year. I have a little modding planned for the front of my wheel well and the rear bumper cover to cure the issue.
I already spoke with the guy for the brackets and he is going to take care of it whenever I get the car over there. The LCAs are poly ends. I did not have any problems with them before. Poly is pretty firm. Like I said I was cutting 1.6Xs all day with 4.10s on a 255 DR. I think the brackets being welded will fix it. But I will keep an eye out on the poly ends just in case. On the pass side the tire only rubbed the inner wheel well. So I think once I pound in that are on both sides and get the brackets re-welded I will be OK for fitment tire wise. Once I get these worked out I have plans to go even faster. I will need a tune and injectors first though.
