90mm TB
The intake pleniumm chamber is more important than the opening size in many respects. This is why the LS6 intake with the stock 75mm TB will generally out perform the LS2 intake with the stock 90mm TB.
And still for this reason the FAST 78mm setup out performas both. The FAST 90 with a 90mm TB (not FAST TB as theirs has issues). Is the ultimate setup for most people and will work well on any LS1 although cammed or h/c setups will benefit more from it.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Originally Posted by TheBlurLS1
I upgraded to a FAST 90/90 and noticed no losses on the butt-dyno. The top end might be a *bit* crispier, but nothing to call the news crew about.
BTW - This was with no extra tuning work (just slapping it on) and I'm also cam-only with shitty '98 heads.
lots of people complain about losses on every part they put in...
wahhh..I lost low end with long tubes...wahhh
wahhhh..I lost low end with a big cam...wahhh..
waaaahhhhhhh..I lost low end with an intake...wahhhhhh
those people need to stop being a baby and realize that if they got a proper street tune with a wideband that they didnt lose anything anywhere...
I have yet to see any mod for the LS1 that hurts low end...they only keep you from realizing the gain because of not properly tuning...
fast intakes work great on any car...theres always more power with more airflow, reguardless of other mods
ok, here is another question instead of starting a new thread. i have a 6 speed car and hopefully ill have a new rear soon with a 4.10.
its just a bolt on car right now, but would it be worth getting the 90/90 setup over an ls6 intake. i want to spray the car sometime soon, and hopefully down the road ill have a stout cam. but is it worth it to get right now?
That's what she said...
Definatly not worth it, especially considering you'll be buying a 12-bolt when that 10-bolt grenades itself. LS6/ported TB is the way to go. Look at it this way, if you ever want to upgrade to a FAST, you'll have $400 strapped to your heads (read: you can always re-sell them).
thanks for the help though, and your right about the resale so it looks like it will be an ls6 intake for me. maybe when i need it (if i ever do) ill get the fast intake
thats what i figured, and if you read correctly (which you didnt ) i said ill have a NEW rear with a 4.10 so my 10 bolt will not have the chance to break.
I'm glad I mis-read it, or there'd be some slapping in order.
I thought you meant that you got a NEW 10-bolt!
i would need a baker's dozen of them to last a weekend of racing.
