Gears & Axles - Need ABS Delete for LT1 3 Channel.
fabgmc4me
06-27-2006, 12:40 AM
I am installing my 9 inch in my 1994 Formula next week. I have 3 Channel ABS on the car and needed to know what I need to delete it, and where I can get it from. I assume I need some sort of block.
Thanks In Advance
SJM Manufacturing Inc
06-27-2006, 02:09 PM
We manufacture ABS delete kits for your car. All kits include proportioning valves and all necessary components. If you don't already have a LL solenoid, we have them ready to go for the kits as well. Our kits enable you to completely remove the entire ABS bracket as well as the modulator to remove ~16lbs of weight from the front end.
www.sjmmanufacturing.com/cam_brk_lt1.html Hit the "ABS delete kit" link on the left side of the page.
fabgmc4me
06-28-2006, 12:52 AM
Which 2 part numbers would I need in order to get both "ABS Delete" and "Line Lock". I need both for the car.
Thanks Again
06-28-2006, 05:15 AM
One part number. You can purchase it as a kit. It all depends on which kit you prefer. 1ABSX1. Check out the descriptions of each to see which you prefer. You want to choose the 3 channel option.
fabgmc4me
06-28-2006, 02:15 PM
Ordered it from you. Thanks
