Collapsed Lifters?
Old 06-27-2006, 10:16 AM
99Ws6TransAm's Avatar
Default Collapsed Lifters?
Is this common within ls1's? I had a pretty nicely bent pushrod..which i replaced. I realized i had one bent due to the ticking. Well after about 3 weeks of replacing it..and the ticking being completely gone..im starting to hear a slight tick again. I have not taken the car into higher RPMS then maybe 4 grand. Could the pushrod being bent possibly caused a lifter to collapse?
Old 06-27-2006, 12:28 PM
CamKing's Avatar
Other way around. The lifter is collapsing, and that causes the pushrod to bend.
If you are running an aggressive cam and/or high spring pressures, the stock lifters won't hold up.
Old 06-27-2006, 12:41 PM
Raven02TA's Avatar
you might just want to see if your pushrods are all torqued right, they could be backing off some.
Old 06-27-2006, 01:53 PM
I thought it was pretty much just 22lbs torqued? And that you neccesary didnt have to use a torque wrence..just go till tight?
Old 06-27-2006, 02:03 PM
Raven02TA's Avatar
thats correct but they can still back out. ive had this problem several times. cant hurt to check.
