Torque specs for starter motor bolts
Old 06-27-2006, 05:30 PM
Mr Ed's Avatar
Default Torque specs for starter motor bolts
Does anybody know the torque specs for the bolts that hold on the stater motor?
Old 06-27-2006, 06:26 PM
That's what she said...
TheBlurLS1's Avatar
LS1howto.com, check the torque specs at the top of the page.
Old 06-27-2006, 06:28 PM
Viper's Avatar
I don't have those, but the AC bracket, PS bracket and engine mount are 37ft/lbs, so logic tells me going into the block would be 37ft/lbs and you'd be fine.
Old 06-27-2006, 06:29 PM
Viper's Avatar
On LS1Howto are they calling the starter the generator? If so, 37ft/lbs like I said.
Old 06-27-2006, 07:26 PM
TheBlurLS1's Avatar
Generator would be the alternator. 37 ft-lbs sounds good to me. I just put stuff like that on "tight-enough".
Old 06-27-2006, 07:29 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
tight enough has never failed me. I only tq to spec rockers, head bolts, and the crank bolt for the most part.
Old 06-27-2006, 07:32 PM
USMARINE1108's Avatar
German Torque it. "guten-tite"
Old 06-27-2006, 09:10 PM
Mr Ed's Avatar
Actually, that's the first place I looked. But I didn't see the starter listed.
So, I think I'll go with 37 unless somebody finds something more specific. Thanks.
vielen Dank.
Old 06-27-2006, 11:46 PM
TheBlurLS1's Avatar
BWAHAHAHAHAHAHA!!!!
That's histerical!
Sprichst du Deutsch? Ich verstehe es aber nicht sehr gut.
Old 06-28-2006, 10:21 AM
Mr Ed's Avatar
Ich verstehe nur ein paar Wörter auf Deutsch. Und Ich spreche sehr schlecht.
Just some of the important stuff like: "Ich möchte ein groß Bier, bitte."
Old 07-12-2006, 10:09 AM
Mr Ed's Avatar
I just happened to stumble across the torque specs for the starter bolts last night. Guess what. GM calls for 37 ft-lbs.
Not that it matters since that’s what I used when I put things together last week but I thought you might like might like to know that you were right on.
Old 07-12-2006, 10:24 AM
Viper's Avatar
Good to know, I'll put it in my keep file for future reference!
Old 07-12-2006, 11:02 AM
TheBlurLS1's Avatar
37 and 22 ft-lbs are the magic numbers for these cars, 98% of the bolts are one of those two.
Quick Reply: Torque specs for starter motor bolts
