Downpipe placement with truck manifolds
i talked very briefly to Jeremy about this (frcfed98) and he couldnt tell me much as hes running a tubular k member. im going to be running a stock k member and planning for a 4 inch downpipe. am i gonna be forced to run that under the k member or can it be done some other way? if under, how is the ground clearence with a lowered car?
first you should definatly run it over the k-member, there is no reason you should run it under, because you can gain alot of ground clearance. on my car i can go over alot of dips and ramps on the road and it hasnt botomed out yet.
next if your running a stock k-member youll have to go smaller, i thought one guy was able to do a 3.5" but i might be wrong.
do you need a 4" downpipe? if you do you'll have to go to an aftermarket.
Im using the bmr, and had to do some clearancing on it and my block, im using the truck manafolds, and the poly motor mounts and managed to fit a full 4" pipe through there barly.
if you want to see pictures look up in the truck manafold sticky, all my pics are there.
i was originally planning on a 4 inch dp but after reading this i think ill probably go with a 3 inch dp and then run the rest of the exhaust using 4 inch pipe. Kaos, did you have to do any clearencing to fit the 3 inch dp? do you have any pitcures of it?
