Manual Transmission - Is my shifter bad?
Lunchbox
06-27-2006, 11:16 PM
I have to let you guys know first of all I am newbie poster so don't hold that against me. I have 98 z28 and I was in line at wendy's last night and my shifter popped out of gear and when I tried to shift it back into gear it took both hands to get it back into gear. When I got it to the garage shifting from gear to gear was very difficult. Almost like you have power steering and then you don't and it takes everything you have to get it turned. It goes from gear to gear but you have to put some weight and very percise with the shifts.
I was wondering if that sounded like the shifter itself maybe the plastic cup at the bottom of the shifter or something. Again I know I sould like an idiot but I am very confused! :bang: :bang: :bang:
chadtx01
06-27-2006, 11:23 PM
You could try removing your shifter and re seating it but I think it would be a pretty optimistic thought to think thats the problem.
It sounds more to me like you might be having tranny problems.
It also sounds like a transmission problem to me. Does it grind when you try to go into gear?
Lunchbox
06-28-2006, 05:20 AM
It doesn't grind into every gear, before this happen it only grinded into 5th gear.
demonspeed
06-28-2006, 06:32 AM
It's your transmission. Synchros or something internal. Possible clutch engagment problems too.
Lunchbox
06-28-2006, 08:34 AM
If the tranny is bad what would I probably looking at with price on getting that fixed? :bang:
BAD99TA
06-28-2006, 11:19 AM
I've got the 5th gear grind as well...sux. If you wouldn't mind let me know if someone gives you a quote on how much it would be to get it fixed, I'm just curious because eventually I'm gonna have to fix it...or pay someone to fix it and that would suck.
Phlip00WS6
06-28-2006, 04:42 PM
You should be able to get it rebuilt for about $500
pro2low
06-28-2006, 05:27 PM
im having a similar problem it is hard to shift and my sometimes will grind 4th or 6th and is almost impossible to get into reverse i have to turn the car off to get it in.....but my car also will start rolling when i am at a dead stop while the clutch is all he way in....so the clutch isnt fully disengaging so im hoping itsd only the clutch problem i think i need to shim it or something still trying to figure tha part out
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
