228R H/C Results
228R H/C Results
The TSP 228R seems to be a popular cam these days. It isn't big by todays standards, but it fit my goals perfectly.
Dynojet SAE 416 RWHP / 387 RWTQ
2004 M6 Coupe
ENGINE MODS
TSP 228R 112LSA
AFR 205's milled to 62cc
Comp 921 springs w/ titanium retainers
Comp hardened push rods
Katech chain
Harland Sharp modified rockers
Ported LS6 oil pump
Dynatech LT headers, X pipe, High flow cats
GHL Bullet catback
Vararam
DRIVETRAIN MODS
LS7 clutch package
DTE strut brace
DTE hardened output shaft
I'm pretty happy with the numbers. They are what I expected, so no complaints. It might do a little better in cooler air (105 degree's) but they are corrected numbers. And we have 91 Octain in Arizona, so not too bad. Also, I didn't use an underdrive pulley because I want the A/C to work at its best since it's so friggin hot here
Well, I'm tapped out for this year. Next year 3.90 gears and Fast 90/90.
2004 M6 Coupe
ENGINE MODS
TSP 228R 112LSA
Katech chain
Ported LS6 oil pump
GHL Bullet catback
Vararam
DRIVETRAIN MODS
LS7 clutch package
DTE strut brace
Those are good results.
I plan on getting the AFR 205's when I get heads (long time from now). I figure roughly 420 rwhp then. We have the same cam and most of the same bolt-ons, but mine's a camaro.
I'd expect a little bit more out of the supposed big horsepower AFR cylinder
heads. Checkout cantdrv65's dyno results, he made 435rwhp with PRC LS6 heads & the same size camshaft!
His PRC heads only cost him $899 because he doesn't even have the
competition valve job upgrade!!
https://ls1tech.com/forums/dynamometer-results-comparisons/529823-tsp-ls6-heads-228-230-cam-mustang-dyno.html
I think we need some side by side results from these big $$ cylinder heads &
the PRC LS6 heads!
the PRC LS6 heads!
Originally Posted by exSSer
Just FYI, the Powerbond %25 UD pulley has no UD on the air cond. belt. That's the one I got, 'cause it gets hot here, too. 106 yesterday.
Although he does have cats, no .040 cometic and no underdrive pulley. So he might hit about 430 to the wheels with the addition of these.
but still...this was a dyno jet compared to my mustang dyno.
And also a fresh 04 ls1 compared to a 98 with 92k miles
Do you have a good tune?
I bet you love the new sound.
Seems a little low to me as well. I was making 430/390 with my G5X-2 cam and AFR 205's. I didn't have a pulley either, and I had headers not as good as the Dynatechs and stock cats holding up some power also.
What is the deal with those modifier rockers?
