yes im dumb
yes im dumb
Ok i did something really dumb last night. I went to reconnect the negative on my batter and accidentially hit the possitive. What fuses could i have shorted out? Also the car would not start after that. i had to disconnect the battery again and reset the computer then it ran. Any thoughts?
well... a good way to find out which fuse/s could have been blown is to see if your vehicle no longer operates as you would expect it to. Is there anything that used to work that does not now? When you overload the circuit, it could blow plenty of stuff so there's not like a set list of things to look for, if your radio doesn't work, i'd look at the radio fuse, if your headlights don't work, i'd look at the headlamp fuses, etc
