LS2 intake manifold..??
Old 06-29-2006, 03:17 PM
Lethal_Ws6's Avatar
Default LS2 intake manifold..??
How does the manifold compare to the ls6 manifold??
And is it a direct swap on an ls1 like an ls6 is .. thanks guys
Old 06-29-2006, 03:22 PM
radz282003's Avatar
I think it will bolt to the heads, because they carry over from the LS6, but, the throttle body is different, I believe. I don' t think it will swap directly over to a LS1 easily. I believe the TB opening is 90mm, but it' s electric and you probably wouldn' t gain a whole lot without a cam and or some heads. I could be wrong on this...
Old 06-29-2006, 03:49 PM
That's what she said...
TheBlurLS1's Avatar
It flows less than the LS6 intake, even with it's 90mm opening and 90mm throttle body. You could have found all this out with a search.
Old 06-29-2006, 04:16 PM
Lethal_Ws6's Avatar
Nahh, just a good way to raise peoples post count lol thanks guys..
Old 06-29-2006, 04:20 PM
viewsonic's Avatar
Many misleading comments about the LS2 intake on here...
You don't have to use a FBW TB on the LS2 intake... Any 4 bolt 90mm TB will work fine.
The LS2 intakes make good power when ported!
Kinda sucks they are getting such a negative spin on them...
Oh and it is not that hard to put a LS2 intake on a LS1... Move the MAP sensor to the front. Get some LS2 injector O-rings, and fab up some washers to secure the Fuel rails...
That's really all there is.
Old 06-29-2006, 04:25 PM
Lethal_Ws6's Avatar
Hm, .. Anybody online selling ls2 manifolds , or even porting them ?
Old 06-29-2006, 04:27 PM
viewsonic's Avatar
I just sold mine... (I got a FAST 90)
Take a look on ebay...
PM me if you want a guys name who ports them...
Old 06-29-2006, 05:14 PM
Danny2tek's Avatar
Im selling one still in the box .....dirt cheap!!
Old 06-29-2006, 05:18 PM
Lethal_Ws6's Avatar
pm sent..
Also, i did a search, and i cant find anyone who Ports intake manifolds.. Anybody know where i can send one off to , to get ported. A number or Link ..
Old 06-29-2006, 05:29 PM
SSDude's Avatar
pm sent..
Look in the LS2/LS7 forum. A few weeks ago there was a thread from a sponsor who was selling ported LS2 intakes. If you get one let us know how well it works. Good luck.
Old 06-29-2006, 07:14 PM
Lethal_Ws6's Avatar
After talking with Jeremy. (Sounds like a good guy,Also real Informative) Im not going to go with an ported ls2, And just do a LS6 or Fast.)
Old 06-29-2006, 08:50 PM
viewsonic's Avatar
Formato?
That's who I was gonna tell you to call
He is tunning my car in two weeks
Old 06-29-2006, 09:31 PM
Lethal_Ws6's Avatar
Originally Posted by viewsonic
Formato?
Yea he sounds like he knows his stuff, post your results when your done tuning
Old 07-03-2006, 04:01 AM
MASS seller approved
smok'nZ's Avatar
damm i am really trying to find ALL the info am seeing alot of negtive post
Old 07-03-2006, 06:31 AM
MNR-0's Avatar
I run an LS2 intake, mainly because I wanted a 90mm Holley TB. Havent noticed anything bad about it yet. I know the test results, and I base that on decreased airspeed, probably due to the lesser CI of a 346 over an LS2. I would hope my cam and heads has fixed that, as its making way more power than a stock LS2.
If the stock LS2 is that bad why arent ppl. changing over LS6 from LS2 and going an after market TB for their LS2s? Probably because the power differences are not worth the effort.
Everybody knows these engines are intake restricted, pulling down head flow numbers considerably. How can an increased plenum volume decrease power? Large plenum volumes are essential for optimum power and torque.
I might get the ported one day, but for the cost of 2x FAST intakes, its not a "bad" mod.
Real world results happen at the track.
