Maximum allowable warpage on LS6 intake
Old 06-30-2006, 08:35 AM
jub jub's Avatar
Default Maximum allowable warpage on LS6 intake
Does anyone know if there is a spec or limit that the factory intake can be warped before it will no longer seal?
When I had mine removed, I put a machinist rule across both sides and it showed it had a slight bow out in the center. My passenger side is running 4% lean, plus there is a slight miss under no load/light load throttle conditions.
TIA.
Old 06-30-2006, 11:39 AM
That's what she said...
TheBlurLS1's Avatar
The 10 bolts should take care of any warp problems, as they will un-warp it as you tighten. You could also try some new gaskets. BYUNSpeed sells a comp cams port gasket kit mainly for FAST's (since they don't come with them), but they will work in LS6's too.
Old 06-30-2006, 01:56 PM
daryl2cb@yahoo.com's Avatar
carquest gaskets 29.99, work good, and might be cheaper then the comps, but if not get them from the sponcer.
Old 06-30-2006, 02:49 PM
jub jub's Avatar
Are any of the aftermarket gaskets thicker than stock or about the same?
