the new inspection stuff
Old 06-30-2006, 02:18 PM
ZL1Killa's Avatar
Default the new inspection stuff
has anyone got inspected lately and you not have cats on your car? they say this new inspection stuff can tell the temps and all that.
anyone have new info?
I will post up a picture of where we got our van inspected and all that it reads on the paper soon.
the place i got inspected at says its a new software and 16pin connector, reads temp and a bunch of other stuff
Old 06-30-2006, 02:46 PM
slow's Avatar
the OBD2 port is 16 pins....
You can tell all that and a lot mroe through OBD2.
Ryan
Old 06-30-2006, 03:31 PM
ZL1Killa's Avatar
i don't have cats, i have the codes turned off. I will get the picture up of the scan here soon. but will the computer show it as me not having cats?
this is the new software update that came i think in January, has anyone gotten inspected that doesn't have cats?
Old 06-30-2006, 04:00 PM
lgobraves's Avatar
Well I have to get inspected in July w/ longtubes, no cats, no egr, no air in charlotte. Codes have been deleted. I will let you know how it goes. Any ideas of places that dont open the hood?
Old 07-05-2006, 03:34 PM
ZL1Killa's Avatar
here is a pic of the new inspection...at least a section of it
this was on our 99 chevy venture
Old 07-05-2006, 04:28 PM
2001NBMZ28's Avatar
"Tampering Inspection" - weird. When I was in Wake County only got a visual and sniffer test, but was a couple years ago - heard they were going to OBDII only.
Old 07-05-2006, 05:55 PM
WS6FirebirdTA00's Avatar
That is nothing out of the normal, that is the visual inspection that is performed. If the codes are deleted they have no way of telling. The wya the testing works is it looks for a trouble code, if its there, it makes sure its emission related, if it is it fails. If the SES light is not enabled, it doesnt look for codes and passes, so we will pass. Whoever you talked to apparently didnt want to inspect and pass your car so they are feeding you a line of bull ****.
Old 07-05-2006, 07:34 PM
ZL1Killa's Avatar
well, maybe the guy they inspected earlier just didn't have his cut off and thats why he failed
Old 07-05-2006, 07:40 PM
LS1TECH Sponsor
foff667's Avatar
has anyone running SD been able to pass the new plug & play emissions? If so how? Ses off & no error reported?
Old 07-05-2006, 08:03 PM
As long as SES enable is set of off you have no issues here in NC. All the cars I do go through inspection with no issues.
Old 07-05-2006, 08:17 PM
Charlie@LsXperts's Avatar
i passed in may, i have nothing.. repeat NOTHING
Old 07-06-2006, 08:19 AM
GuitsBoy's Avatar
From what I understand, not possible. You need it to throw a code in order to revert to SD mode, otherwise it will simply factor in the lowest MAF value and will likely stall teh car.
Old 07-06-2006, 08:31 AM
horist's Avatar
From my understanding that's not 100% true.... from what I understand, they (govt) currently don't check to see if the OS is stock... however, I've heard from a few sources that they (EPA inspection places) actually download the full PCM flash when they connect...
If this is the case... they can tell if the PCM is alterred... but thing is it's not currently worth the effort to check (since there are so many OS's for a given model year... imports are even worse than the LSx PCM I believe)
For now though they just check for an SES and the readiness tests
Old 07-06-2006, 11:09 AM
soundengineer's Avatar
usually you just leave SES enabled and set error codes to "no error reported"...and it passes...
SD its not possible to do that....if you set SES on and No error reported for the MAF the car wont even run no matter what you do...
Old 07-06-2006, 11:16 AM
keliente's Avatar
That's not new - that is just a list for the visual part. Do I see a cat? PASS. Do I see o2's? PASS.
LS1TECH Sponsor
foff667's Avatar
thing is I dont think maf is part of any readiness tests meaning you could turn off the ses, set them to no mil & you should be able to pass as far as I can see...wish I had a test dummy car
Old 07-06-2006, 12:09 PM
slow's Avatar
I can't see them actually pulling down a stock file to do a conparison. However, there are numbers that can be used to determine if a stock file is in the vehicle....
Ryan
Old 07-06-2006, 12:26 PM
daryl2cb@yahoo.com's Avatar
passed in march, no cats, no air, no egr, cam, no issues, and no ses light, he pluged it in and I was done, he told me in PA 1996 and newer no codes =pass, no more visuals.
Old 07-06-2006, 02:27 PM
F-117HWK's Avatar
Anyone know what the deal is in VA?
Old 07-06-2006, 07:52 PM
ZL1Killa's Avatar
awesome then, i will give them a face when i pass and they will look at me like wtf??
lol
