beck intake
beck intake
I have a 408 with etp 255 heads and I'm going to be ordering a Beck intake my questions are what throttle body should I run a 90mm or bigger and what should I have them put in the back of the intake if I want to run the ac/heat and brakes and map sensor. I talked to them but they didn't really know
What web site is there to look at these. I`m in the same boat you are. My ET 245`s outflow my fast 90 combo pretty good. I need to step up and want to research before I do. Thanks! Granted, with these heads, even being A4 and locked converter my TRQ numbers where over 500 at the wheels. I just stop making power at around 5500rpms. Just can`t get enough flow threw the system!!
