detonation?
Old 07-01-2006, 12:55 PM
dub.ya.es.SICK's Avatar
Default detonation?
ok I got full exhaust and a lid and85mm delphi maf, and ported tb. from like 4500 to 6000(I barely take it there now, the noise scares me.) it is a horrid rattling noise, I havnt had it tuned yet but I assume its knock or detonating...can I fix this? it happens more in hot weather. also how would I retard my timing, to fix it.....is my motor firing to hot? i gap mine at .055 how can I fix this without a tune.....98 ws6 m6.
Old 07-02-2006, 01:12 AM
rich Z's Avatar
If you have the stock maf then put it back in. I had a z06 maf and it made my car runs extremely lean. Enough to eventully give a lean code. Another cause is carbon buildup. Get a catch can to slowdown oil from making its way into the intake and top of the pistons, valves. Then do a seafoam treatment to clean the carbon out.
Old 07-02-2006, 09:52 AM
TunedPower's Avatar
Log the A/F ratios, throttle position, rpms, ambient temperature and total spark advance (and compare to some stock baseline) to see if your mods are causing the PCM to run to lean and/or too much timing for given conditions.
