Forged internals???????
I just bought and installed a forged 347ci LS1 shortblock from Texas Speed for 2700, give or take. It came with forged pistons, rods, the works, still stock crankshaft though. It's a ******* beauty. If you are serious about forged internals, I say just go with a brand new shortblock. It's money well spent if you plan on installing everything yourself.
Originally Posted by ls1_cam2
Sounds like a good deal and will look into it, but like you said its a stock crank and was wondering is that ok or does it need to be replaced??
There are numerous LS1's in the 8's and 9's running stock cranks.
As for parts in a forged short block: pistons, rods, rings, bearings, bolts.
I'd also add a new timing set and oil pump to the list if you want to do it right.
As for cost - $2,600 - $3,000 on the cheap side and $4,000 - $4,500 on the expensive side.
As with most things in life you get what you pay for - not all forged motors are equal.
Without the block doesn't EDPC (sponsor) or something like that? sell forged pistons, rods and i'm not sure what else...for like $900ish? And forged stroker kits also. As far as boring the block goes, i wouldn't think so but i can't honestly can't answer that. The Mahwe(sp?) pistons aren't any bigger are they? Question: When you buy a "forged block" are they just stock blocks that are heat treated or something (whatever makes the aluminum stronger) or are they a totally new block? sorry to hijack.
Moderator
As for MAHLE pistons, they are offered in a variety of sizes, much like other piston manufacturers, to fit most applications. Unless your engine block is brand new or has VERY little mileage, your gonna want to hone the cylinders to straighten them out. Therefore, you'll need a larger piston to fit the larger bore.
Moderator
One more thing, if you hone the cylinders out to 3.905" and buy some aftermarket 3.905" forged pistons, you'll get a paper in the box saying that you'll need .004" piston-wall clearance (roughly). DO NOT assume that the piston is 3.905" in diameter and hone the block to 3.909" to acheive that clearance. It's made to fit a 3.905" bore and has that .004" clearance already.
I would too. just the tools you need to build a shortblock would be 500 bucks or so
Originally Posted by KCS
Forging is a process thats used before the metal is shaped into an engine block. Forged blocks exist in Top Fuel and tractor pull competitions, not anything anyone here could afford.
Moderator
Let me rephrase that, i meant the "stock" forged ls1 pistons....if that makes sense lol. Thanks for clarifying though, i get what you're saying now. So noone actually uses a forged block, just pistons rods etc.? i was always under the assumption that some people on here had forged blocks also i guess, soo the stock aluminum blocks good to ______HP???
