Install pic of threaded IAT sensor in EGR hole and 4" MAF.
Coal Mining Director
Originally Posted by frcefed98
Looks Killer, I think i'll drill and tap my intake for my threaded IAT sensor too. Best place for a IAT reading i'd think.
J
J
Originally Posted by onfire
Don't have to worry about it blowing out under high boost that way.....can't wait to get my alky kit to try out.
Originally Posted by Fire67
Wont the alky coming in through the TB affect the readings of that? The IAT would come in direct contact with the mist.
Sensor is a GM# 25036751 for $38 through GM (for a 1991 Syclone). 3/8" 18npt.
Adapter is a LPE map sensor relocator for c6 vettes...the map sensor hole has to be enlarged on a drill press and tapped for 3/8 18npt for the IAT sensor. LPE # LN-BK28kit for $67
Then it just presses in the egr hole (has a oring seal) and the the retainer screws into the existing screw hole for the egr.
That's why I relocated the IAT to the intake. I WANT the alky to hit the sensor....that way I can tune the timing vs IAT table to pull timing if the alky kit fails....if the alky is flowing = cool air = more timing = more power. If the alky kit fails = hot air = less timing = saved engine.
Or does that not matter... As long as the timing is correct for what the IAT sensor reads I guess it'd be fine.
Very cool concept, I like how it sounds... Use the PCM to make sure you dont blow your modded motor if/when the meth fails.
Originally Posted by Vortech
If your doing this on a LS6 intake can not just drill and tap it?
Originally Posted by bczee
Well this work for non Force Induction?.. Will moving the IAT To the EGR Port cause any bad or drivablity problems.
Thanks
Thanks
