The page cannot be displayed
"The page you are looking for is currently unavailable. The Web site might be experiencing technical difficulties, or you may need to adjust your browser settings."
This apears when I trying to acces from my house. I am using the bigest internet service in Mexico provided by Telmex named Infinitum.
I can acces here if I change the proxy server.
Do you know why this forum cant be reading with Infinitum service?
Thanks.
HZ
Thanks.
HZ
Hm.
How long has it been doing that?
Have you tried accessing it (with Infinitum) using ls1tech's IP addresses instead of the domain name?
http://67.15.111.194
http://67.15.111.195
http://67.15.111.196
Originally Posted by ACW
Hm.
I have had the Infinitum since 6 months, but I had to access the forum every where but here in my house, until I found those proxy servers.
Thanks, you will see me more offten here couse I just change my 97 A4 for the 01 M6, and now I can acces from my house.
HZ
Originally Posted by hz28
wow, I just bookmark those IP Adresses, thanks.
HZ
HZ
Anyone knows the IP addresses of www.performancetrucks.net?
I have the same problems hz28 was having to log in here.
Thanks.
Thanks.
open up a command prompt and type in "cmd" on XP or Win2k, and then when the window opens, type in "ping www.performancetrucks.net".
The IP it shows will be the IP address to use.
Should look like this:
Thanks cyphur, I tried it but said: "can't find the host" , I tried with other websites and it works, but not with www.performancetrucks.net
Any other choices?
Thanks again.
Any other choices?
Thanks again.
Originally Posted by cyphur
That sounds like your service provider's DNS is having some issues.
FWIW, the IP address in my image is the one you need to use, if you noticed, I ping'd PT.net.
I'll let you figure out how to get around that.
Damn cyphur, I saw 10ms ping times to the server, and thought "wow, that's friggin FAST!" ... Until I pinged it from my connection at work
Code:
C:\>ping www.ls1tech.com Pinging www.ls1tech.com [67.15.111.196] with 32 bytes of data: Reply from 67.15.111.196: bytes=32 time=2ms TTL=57 Reply from 67.15.111.196: bytes=32 time=2ms TTL=57 Reply from 67.15.111.196: bytes=32 time=2ms TTL=57 Reply from 67.15.111.196: bytes=32 time=2ms TTL=57 Ping statistics for 67.15.111.196: Packets: Sent = 4, Received = 4, Lost = 0 (0% loss), Approximate round trip times in milli-seconds: Minimum = 2ms, Maximum = 2ms, Average = 2ms
Code:
24ms here.
Well, I'm in the same city as the servers which helps.. We also colocate the fiber optic equipment for a local carrier, so our connection is pretty darned good
I'm at 30ms from home... TWC has started to stink, its slowing down...
