2.4 60's = 12's ?
2.4 60's = 12 sec club?
I went to the track a couple weeks ago to see what my winter mods did for me. I went from a bone stock 2000 SS to a H/C/I car over the winter. Im on 18" Z06 rims with a Yokohama street tire. My time slip was as follows.
2.4082----60 ft
5.8240----330 ft
8.6029----1/8 ET
12.8409----1/4 ET
115.66----1/4 MPH
18'' street tire, M6 Tranny, 347 LS1, No power adder.
Here is a video of the pass, Im the car on the left, listen to me lifting because I had absolutely no traction
http://s48.photobucket.com/albums/f2...=race6mpeg.flv
2.4082----60 ft
5.8240----330 ft
8.6029----1/8 ET
12.8409----1/4 ET
115.66----1/4 MPH
Originally Posted by Hennytime
with decent dr's your a mid 11 second car
Originally Posted by BIG_MIKE2005
Man with a better 60' you should easily be a mid to low 12 with your power level. Even with the stock 10-bolt.
Originally Posted by AOC
2.4 short time??? Ouch.
I think if work on (lot of practice) your launch, you certainly can improve your short time, possibly into 1.9xx with street radials.
ok, time to look at suspension then. Get some LCA's w/relocation brackets, panhard bar, & torque arm. You should loose wheel hop. And these will definetly improve your 60' & help you keep hooked up.
Also don't forget to just barely spin the tires if they are street tires. I only spin mine enough to clean them & get em' a little tacky. I also avoid the burnout box & then back into it just enough to get a little wet patch on the tire, then spin em' & line up.
Thanks for the tips! Suspension parts are farily inexpensive aswell arnt they?
Talk to Ryan @ UMI. They have a package with LCA's/Panhard for like $185 or so. Then all you would need would be relocation brackets (about $60). Thats should give you a better start. Then as you get more money get the torque arm & some Sub Frame Connectors.
Cool thanks! I have SFC's already so, all I would need is the torque arm and then the 12 bolt
