Quick Oxygen sensor question
Do i need to wait to take the Oxygen sensor off after I pull the exhaust manifold off on the drivers side or pull it off before I pull off the manifold. I got an o2 sockets it just a bitch to try to get it on it. Or is it possible to get it with a wrench?
That's what she said...
I've allways used a big *** crescent wrench on my O2 sensors. Make sure they are good and tight so you don't have to go to the hospital. If you can pull the manifold with the sensor still on, then remove it with the manifold in a vice it would probably help.
If you don't have a vice or some other way to hold the manifold tight, I'd defiantly use a wrench on it.
Just went through that this morning, and I could not get the drivers manifold out with the O2 sensor on, I tried the O2 socket, no go, finally got a wrech and got it off, and busted my nuckle
The drivers side rear o2 harness plug in is a bitch to reach 2. guess Im gonna try and get some pliers on it any other way, any way of just leaving it connecter sense I got The ORY pipe
Waiting for the opportunity to have it on a lift so I can get to it. Not too much clearance with floor jacks.
And no problems since I had the rear O2s deleted via tuning.
