11:77:1 Compression on pump gas
Yes, this is an opinionated question. So, whats you opinion. Is 11.77:1 to high for pump gas (93) octane?
Thanks in advance
Also, can you double check my math
Bore 4.060
Stroke 3.82
Deck height .007
-2cc dish piston
gasket .060
cylinders 8
head CC 59.45
Thanks in advance
Bore 4.060
Stroke 3.82
Deck height .007
-2cc dish piston
gasket .060
cylinders 8
head CC 59.45
LS1 Tech Administrator
Totally depends on dynamic compression. You could be running a lazy cam with big duration (like a 240/248 115LSA) and only have 7.8:1 dynamic compression. This would be OK on pump gas. Or if you were running a 220/220 110LSA +4 cam, this might put your dynamic compression above 9.0:1 and the motor would rattle its *** off on pump gas. Again, depends on cam timing. As a general rule of thumb, you can run up to between 8.3-8.5:1 on 91 octane and 8.5-8.8:1 DCR on 93 octane. FWIW, the DCR with the stock '98-00 cam is 6.9:1.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Originally Posted by cws T/A
what DCR does Pat G's cam put a Stock 00 ls1 at , can I mill my 241's
__________________
Think this combo would pull 400rwhp my stock 241s , milled for 8.5 DCR + your highlift torque cam + fast 90/90
__________________
Remember, it's not just dcr that comes into play either. It all depends on the cylinder pressure your motor generates. The lsx manifolds are probably more sensitive to compression considering they work much better in the midrange then the single plain/sheet metal intakes and more time for detonation will be present in the midrange then in the higher rpms. So basically if you have a high rpms type setup (via intake tuning) you can get away with a little higher dcr i'd think. Also, your heads combustion chamber, heat range on the plug, yadda yadda all in the combination will make or break your tolerance for pump gas.
Hell, if you didn't ever go wide open throttle you could probably get away with 13 to 1 on pump gas but as soon as you go wide open, unless your cam is silly silly late on IVC then you're going to have a pop corn machine
Originally Posted by Taphee6
If I remember correctly on my current set up cylinder pressure is 200.
