Casper electronics V-plus volt booster
Old 07-04-2006, 01:19 PM
kp
kp's Avatar
Thumbs up Casper electronics V-plus volt booster
Since relocating my battery to the trunk my overall voltage had dropped some on a pass so I thought I would finally install the casper volt booster I had laying here for a couple months. After seeng Mightymouse had good results with one a while back I ordered one but never got around to putting it on.
Dont know how it works exactly but I figured now was the time to try it. All I can say is it works as advertised so far, just made a couple quick high gear blasts and sure enough it bumps the voltage a solid 2 volts which makes a pretty big difference with these two walbro pumps. If it works during a full pass (I notice sometimes the alternator shuts down on a full pass) its a great 80.00 investment..
Old 07-04-2006, 03:07 PM
eb02z06's Avatar
Can you use it in conjuction with a KB BAP? Will it work on a C5?
Old 07-04-2006, 03:13 PM
kp
kp's Avatar
I probbaly would not use it along with a BAP, the BAP output is regulated so I would think the output voltage would stay the same even though the input voltage is raised.
It should work on a C5 as long as a C5 had the regular round TPS connector - I forget if it does or not..
I assume it just 'full fields' the alernator somehow so the alternator will be working harder. But since it only works at 70% and above throttle it should be OK. See what happens at the track in a few days..
Old 07-04-2006, 03:30 PM
cablebandit's Avatar
interesting...I might get one of those for a little more fuel cushion
Old 07-04-2006, 03:41 PM
kp
kp's Avatar
Not only does it give a couple more volts for the pumps but the ignition will most likely put out a few more zorcons as well
I didnt think it was going to work at all on these newer CS alternators but it works as advertised. Had a multimeter taped to my windshield plus logged the voltage through the PCM and there was a solid 2 volt increase.
Old 07-04-2006, 03:53 PM
Frost's Avatar
Originally Posted by kp
.... Had a multimeter taped to my windshield .....
That's dedication.
So this piece raises raises the entire effective voltage for the whole car rather than acting like a BAP? My first impression of the device was it just had a very healthy DC2DC converter in it, but one that would encompass the high current level such as total vehicle load would have to cost more than $80... and I don't know how effecient the current offering of these are either. I would tend to think that pulling up the field would be an easier and more realistic solution as well.
So how does it wire up?
Old 07-04-2006, 04:01 PM
kp
kp's Avatar
Back in the old days I would just pay a kid to ride under the hood and watch the meter but these new child labor and traffic laws frown on that
It just plugs into the alterator connector and TPS plug, one wire goes to the alt output wire. I was able to put it on from the top in like 5 minutes. If you have the ABS motor still there you will have to do it from underneath I think.
It raises the voltage to the whole car, it works off the TPS and when it reaches a certain point the voltage goes up.
Old 07-04-2006, 04:02 PM
Ed Blown Vert's Avatar
I run one also. It increases the voltage at the alternator.
EFI Live also verified the extra output. Its just enough so I don't run lean anymore.
I will still need to add a BAP later..
Old 07-04-2006, 07:06 PM
TwnTrboCE's Avatar
I would say you need more pump if your using this and think you still need a BAP.
I tried one on the CE the other day at the track and voltage was at 15 all the way down the track. You will need to adjust fueling for this if your pumps start supplying more psi. I was blowing smoke from the hit. More fuel and more Meth made for a very rich pass. It works though.
Old 07-04-2006, 10:18 PM
618HAWK's Avatar
I have had good luck with mine as well.
I would recommend to those who plan on getting one to get a TPS harness extension kit as well. Its connector harness is rather short and makes it so it needs to be left hanging near the TB. Kind of a shady install. With the extension harness will give you more otions for a install. Only thing to be cautious with is to keep it away from any other electrical items, due to possiable problems. "As per Caspers Tech"
Old 07-04-2006, 10:59 PM
DJ's Z's Avatar
I would recommend to those who plan on getting one to get a MAF harness extension kit as well. Its connector harness is rather short and makes it so it needs to be left hanging near the TB. Kind of a shady install. With the extension harness will give you more otions for a install. Only thing to be cautious with is to keep it away from any other electrical items, due to possiable problems. "As per Caspers Tech"
Any info on where we can find the MAF harness extension?
Your exactly right we were very limited on where we could install it and put it in a temporary location...
Old 07-04-2006, 11:01 PM
kp
kp's Avatar
I had no problem with the length of the wires. Was able to wire tie the module to the evap solenoid line and there was plenty of wire going down to the alternator..
Old 07-04-2006, 11:05 PM
where do you get this apparatus?
Old 07-04-2006, 11:10 PM
ABeasst's Avatar
I know ls1 speed sells it as well as some other sponsors
Old 07-04-2006, 11:12 PM
Jammer's Avatar
https://www.casperselectronics.com/M...&Category_Code=
Old 07-05-2006, 12:19 AM
618HAWK's Avatar
Here is what I used, Note you get 2 per kit note one. Which is needed.
And Let me correct my last post. I meant TPS not MAF.
https://www.casperselectronics.com/M...Category_Code=
Old 07-05-2006, 09:50 AM
ABeasst's Avatar
ls1 speed sells the extender too.
Old 07-08-2006, 11:14 PM
kp
kp's Avatar
Thought I would bump this up and say that thanks to this thing I am able to squeeze just a little more out of these dual 255s and 57lb injectors at the track last night - works exactly as advertised. Was able to knock my duty cycle down a few percent and the fuel pressure is holding a little better now. Not bad for the $$.
Old 07-08-2006, 11:50 PM
cool. I will get one if i can get off that page watching your vid!!!
Old 07-09-2006, 12:13 AM
kp
kp's Avatar
It works, pic of the voltage during a pass. The PCM reads about a volt low, it goes from 13.1 to 15.2 or so on a voltmeter hooked to pump relay. The bottom green line you can see the voltage jump up and stay solid the whole pass.
Quick Reply: Casper electronics V-plus volt booster
