Rasp Question ???
Rasp Question ???
I have Hooker Cat-Back now and plan on getting Pacesetter LT + Pacesetter Y pipe.
I have done a little reading and saw that running a Catted Y pipe may give me less rasp sound than running no cats. ???
Any truth in this? Will it quiet it down a lot? any loss in power between the 2?
Bottom line is I want no Rasp.
Thanks
Thanks
well with the hooker catback you will have no rasp. Having the cats you may lose 5 hp but nothing big. Hooker catback has been known to not have rasp even with the ORY so ur good to go. I just ordered the hooker catback for my ride and i have the same setup you do...LT's and Catted Y.
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Maybe we should define where rasp originates. LS1's are gonna have or at least tend to have some rasp anyway. The hooker is a pretty "raspless" in my opinion too. The charateristics of the aluminum block is a main source of rasp due to its resonance. Having open exhaust is going to let it show it's ugly head even more-so. That is why you hear the "keep your cats" saying when refering to "Will I have rasp with ORY, LT's, and bullets?" questions.
Well no one I can find has this set-up that lives around so that I can hear the difference between catted and without... so If no Rasp= keep the cats then thats what I will do.
thanks,
Shawn
thanks,
Shawn
Tech Resident
run cats. all catbacks rasp with an ORY, yes, even the hooker. so why do people say it doesn't rasp? three main reasons:
1.) most people don't know what their car sounds like since they've never heard anyone drive it
2.) some people can tolerate rasp better than others
3.) some people don't even know what rasp is! (it's that BLAT BLAT noise on decel when you rev it high)
a catted y will get rid of the rasp much better than an ORY will. however, even with a catted y, the LS1 is usually not 100% rasp free. it'll just be far better than an ORY.
And no, chances are your Hooker won't rasp / will have VERY little rasp as long as you're running a Y pipe with a flowmaster style collector, such as the mufflex. I've had this setup on 2 cars, one that was just boltons/cammed, and one that was heavily modified, both had a clean, deep exhaust note all throughout the powerband. If you run a Y pipe like you're describing, as the one you can buy with pacesetters, or any in which the pipes just run into each other as a collector, you will experience rasp.
Hope this link works... http://www.ls1sounds.com/Hooker/hook...LT_3in-ORY.wmv
this link is from LS1sounds.com I went to Hooker section, then down towards the bottom where it says " Pacesetter/ORY/Hooker/3"system"
When I watch the video, it sounds good to me until...he stomps it then lets off he does it a few times. So yeah I think that the noise that I dislike/call Rasp is on the way down when he lets off the accel.
That seem right to anyone?
thanks again everyone for helping me out...its tough to make the decision when I can't hear in person
Tech Resident
Originally Posted by LSUxBlake
Most people consider the high pitched sound that occurs roughly between 2200-2600 rpms on accel rasp.
*BLAT BLAT* is rasp. the noise you are describing is more like drone. i know what you're saying, my old V6 did it at 3000 rpm's on the dot. sounds like ****. another reason why i love my dual/dual.
http://www.lsuxblake.com/Trans%20Am/SLPDD.wmv
Tech Resident
what i'm saying is people usually confuse drone with rasp. that high pitched sound - which sadly is a raspy high pitched squeel, which causes a lot of people to consider it as rasp - that causes interior resonance is just drone. it doesn't have to be long resonance on a highway to be considered drone. even if there is interior resonance for 2 seconds, that's 2 seconds of drone.
rasp is just hard to describe. BLAT BLAT is the general definition of rasp but the best adjective to describe the sound at around 2400rpms with a hooker w/ORY is, well, a raspy drone...
we need to invent other terms...rasp has 2 different definitions
Magnaflow HF cats cost me 9rwhp @ about equal rwtq back when I was cam only. The slight power loss was well worth it as the sound was great. Even with the Corsa muffler it had no rasp at all after adding the cats at any rpm. The Corsa was pretty raspy in the 2200-2800rpms range with the ORY. I've only ran my current Hooker muffler with cats so I have no experience on the sound with an ORY. Although it would be hard to beat the current way it sounds with H/C LTs Cat Y and CME....
so you like your hooker catback with the LT's and catted Y?
Just wondering if you noticed a difference in the exhaust smell / strength of the fumes when running the HF cats.
Yes with the HF cats there was a noticeable drop in exhaust smell and fumes. While it was never really bad with the ORY during normal driving the sticker was when I pulled the car into the garage. The fumes were pretty intense.
