Do I need dual springs?
I plan on picking up a Lingenfelter LS1 GT2-3 cam (207/220 573/.580 118cl)
and was wondering if dual springs like PRC's are overkill or are they necessary?
Here is a link to the cam:
http://www.lingenfelter.com/store/ls1-gt2-3.html
Thanks guys !
Thanks guys !
Well, I noticed Lingenfelter sells the same cam as a kit with LS6 springs so apparently they feel single springs are sufficent....but I definitely understand what you are saying........
You don't need them, but they are good for insurance purposes. In the slight instance that you do break a spring, you won't worry quite as bad about dropping a valve and completely toasting your motor.
LPE cam GT2-3 will run on 02+ LS6 springs.
Myself I would put 918's on it.
Duals are complete overkill and have too much seat pressure for that cam.
Over springing can have negative effect on lifters.
10 Second Moderator
