HP from A/C removal?
I am finishing up my cam install and was wondering if I left the A/C belt off I might see a little more speed or lower E.T's out at the strip? It makes sense that i would gain a little..
That's what she said...
These guys are right. The a/c compressor has a clutch that unlocks when the a/c is turned off or you go WOT. You won't see any gains from removing it. Now removing the entire system will drop a little weight from the nose of your car and help out, but it then you sweat your *** off.
Location: Vancouver,[KITSILANO].B.C. Canada *WestCoast*
Originally Posted by ChocoTaco369
not enough to justify the added weight from all the sweat in your car. AC only matters when it's running to my knowledge. i feel like i'm towing a boat with it on.
Originally Posted by NHRAMAN
I have ran with it on and off...no difference really..it cuts out at full throttle.
