This chirp is driving me INSANE!!!!
I have this annoying chirp that sounds like it's coming from the back of the motor.. It sounds like it COULD be the tensioner issue.. but the chirp exists with all of the belts OFF of the car.
It will vary with RPM and disappear about ~2300 or so.. It's extremely evident at idle.. embarrassing as hell at red lights...
What the hell is it? Stuck lifter maybe? Would some seafoam in the crankcase maybe free it? HELP!
check out you clutch area,i would pull the tranny check the pressure plate torque specs,if its not torqued correctly you could get a whobble on the tension fingers and that then wobbles other stuff like the slave surface.just something to check,I dont know what a spun bearing sounds like either,but i would look into it.
o man you have this too? I have the chirp form the back of the motor(close to the firewall) sounds like it is coming from under the intake on the trivers side. However mine goes away when the car is warm.... If you get your figured out plz let me know.
thx ab
thx ab
I had this chriping sound and did everything I could think of but could not find were it was comeing from then on day my clutch locked up and when I got in there to change it out I found a spring that came out of the disk.well when got the new clutch in my chirping was gone.It sounded just as you guys discibe.I had the spec stage 3 What clutch are you guys running??
"Chirping" is the word people most often use when they are describing the sound they hear coming from a bearing going bad. This means needle or ball bearing noise not from big end rod or main crank type shell bearings. The sound they make is not described using the word "chirp". I was going to guess clutch throw out bearing, but since you say the clutch doesn't have an effect on the sound and you have removed all the belts and still hear it that doesn't leave a whole lot to blame it on. Try and locate it with a mechanics stethoscope. It's time to "Go Fish"!
I have the noise. It is only when I am decelerating. NEVER under acceleration. And it's much more evident with my cutout open, so I'm sure it is either internal, or exhaust-related. Doing a head/cam swap soon so we'll see if it's in the upper engine. Also my rear passenger side header bolt was broken when I got the car, so mine could be coming from that. That also will be fixed during the swap, since new heads are going on.
Originally Posted by juiSSed1172
a header leak can sound like a chirp? i'll give it a shot.. but that sounds odd...
Update:
I poured 1/2 can of seafoam into the motor on Thursday morning.. drove it for about 75 miles.. no change. The next morning, the chirp was gone. The only other thing to have happened was that the car sit through a rain storm for the night.
Who the hell knows what's going on...
Ok, My A4 has the same chrip. Sounds like a bad altanator, but its not the problem. I have done the stethoscope thing and can't pin point it. only hear it at idle, touch the gas just a bit and it goes away. And it only does it sometimes. Driving me insane also.
