2000 Ls6 block engine replacement factory warranty
Is it possible a year 2000 car that had the engine replaced in 2001 due to ticking under factory warranty could have the LS6 block?
Originally Posted by VA2001SS
All LS1 engines from 03+ (C5,GTO) had the LS6 block, so LS1 warranty replacements from then on would most likely have had the LS6 block.
i thought it was '02+
I have seen other threads saying x% of fbodys had ls6 blocks. the people in the threads had sources and seemed creditable. anything is possible if your block was replaced in 01 or later. the only real difference was cooling passages i believe. you do not gain anything by having a ls6 block as far as power. in the old threads they had ways to find out what was in the cars. try doing a search and see what comes up.
